Yes-the YSE is the horizontal version. I had a YSB in a Lancer I had-couple boats back-after I put clutch in it I never had a problem out of it. This one always cranks up and runs strong-only issue has been the Fuel coming out the exhaust. I won't know what it has for a prop till I haul the boat next month for bottom job but will yank the prop then and go over it as well as this boat will be taking me to Florida and Bahamas in January/Febuary. In the meantime I ve been sorting out the (very simple) systems to see what needs altered or upgraded..its a pretty barebones boat but that's what I want_keep it simple and there's little to go wrong you can't fix. I hope. Lol Thanks for your input-i ll check over all you advise.
David
