battery terminals and cables after the boat has been out cruising for awhile?
But, you are right, it probably doesn't matter that much.
We use three batteries in parallel with no starter battery (crank). The charger goes from the furthest pole of one battery and the opposite pole of the closest battery. Charges like one big battery.
