... water when I am discharging overboard, I think water is getting past the seal in the Y-valve, even thought it is turned to the discharge position, and going to my Holding Tank. I've tried a number of things to locate the problem, and I'm fairly convinced this is the problem. I took the thing apart last year and cleaned it all, still had the problem.
thanks, cheers, John
