During the initial pumping of water I did NOT use the 'Mr. Filter' but went directly into the 5 gallon bucket. If I had used the filter as I said, nothing would have gone through.
My mistake in remembering what I had done. I used the Mr. Filter only after disconnecting the feed tube from the Racor.
