At this moment she's rounding Cape Horn. http://soloround.blogspot.com/ ---- and ---- http://www.abbysunderland.com/
Cuts from recent blog.
The swells are pretty big - about 20 feet. It makes it pretty uncomfortable crawling around down below in the aft end of the boat. I'm using my back up auto pilot right now and I want to get my main auto pilot fixed so that I can use it as a back up. The problem is that there is a pretty bad transmission fluid leak (the steering is hydraulic). I think the leak is in the ram but I can't find it without the auto pilot turned on. I should have some pretty calm weather in a few days so I'll be able to turn off the autopilot, lash the tiller and hook up the first auto pilot and get a good look at things working down below.
Before the wind vane debate gets started up again, know that there is not a suitable wind vane for a boat as fast as Wild Eyes and that that is why I don't have one.
I've had some problems with my water maker recently. I think it's just that there is air in the tubes and I am really hoping I'll be able to sort it out with the bleeding valves. If that doesn't get the air out, I could have to go through all the hoses back there which really wouldn't be a very fun job.
It would almost be fun, if things could only break down during the day!
