I've never heard of one failing to an extent that threatens the boat, but I guess it could happen. I keep an automotive radiator hose repair tape aboard, which should be able to patch the rubber. As for the vent fitting breaking off, I would probably use plumber's epoxy putty (the kind that comes in a stick, that you knead in your hand to activate, and sets in minutes).
