Return to Index
Read Responses
Weather and politics are heating up.
In Response To:
Thanks, Peggy. How are things in the lower edge of the midwest? :^)
Get Rid of Boat Odors!
Marine Head Question
Route the hose from the head directly to your holding tank...
Forgot the pic
The problem is...
Stuck vent relief valve in the vented loop
another possibility
valve
You're sure there's not an oclusion of the discharge line?
Air valves have a life span...shorter if they aren't maintained. They require periodic cleaning and replacement.
About how long if one flushes the lines with fresh water once a week (or before one departs the boat)?
No "cut and dried" answer...
It's that time of year for both -- at least one doesn't bring tornados. :^)
