Marineair thermostat
i have a marine air AC unit that is not getting cold enough. There is a sensing bulb that is connected to the control panel with a long copper wire. Does anyone know where this sensing bulb is supposed to be? I found mine sitting in the condensate water under the evaporator fins. This water is quite chilly. Would this be a place that the tip of the sensing bulb should be resting??
Thanks!
Rodd
