I'd stay away from it.
In Response To: Strainer and Impellors ()
I assume that you have an strainer between the thru-hull and the engine intake?
A strainer will reduce the volume passed by about 1/2. A proper strainer (BEFORE the engine) has a much larger cross-sectional area than the hose, for example.
