Return to Index
Read Responses
Also check the tank vent (NM)
In Response To:
Diesel Problem
Diesel Problem
Engine and Air
Couple of thoughts...
I second this . . .
Evaluation for fuel starvation .....
As mentioned above, check the tank vent.
Vent checking
A blocked vent will show up as high vacuum on a filter mounted gage
I ran into an identical case of this several years ago...
Exactly the same thing happened to me.
