Return to Index
Read Responses
Thanks Nat!
In Response To:
Winterizing....
Winterizing a hot water tank?
Winterizing....
Thanks Nat!
You need to deal with the lines from the heater to the various fixtures?
Same here although I don't
That works -- unless it doesn't ;^)
I always winterize the lines!
I winterize the lines with non-toxic antifreeze...
I thought you folks in the north used Vodka to winterize...
HEY! I resemble that remark!
build a little plumbing bypass
I too bypass the heater..
Unabashed plug! -- great article about winterizing in Sept/Oct Good Old Boat
