You can go online and ask Facet for a recomendation.
They are responsive.
http://www.facet-purolator.com/index.php
Also, note from the Racor installation manual if you are installing this between your tank and filter.:
Pressure Side:
Fuel transfer pump not to exceed maximum PSI or flow rate of filter.
Not ideal - pumps emulsify water hindering filter performance
Paul L
