Due to the cheating and...but I digress, the "builder" failed to properly cover the hull exterior with Dynel. I added in bits on both transoms and all along the starboard side below the gunnel. Then it was ground down to fair with the feathered areas which were actually done as they should have been.
After adding in and sanding out two days worth of fairing compound on thop of what you see here, that job is done and I'm looking at the rub and toe rails for design.
Where the "builder", henceforth to be known as "numbnuts", bored so damn many holes in the hull and then poorly puttied them I will grind out divots and Dynel and fair those areas. Poor workmanship, lazy ass...numbnuts.
It's what keeps me a doityurselfer, damn it!
