IMO, time to upgrade to a Lavac or a Raritan PH II or PHC...which, if you go with a "conversion" (everything but the bowl, seat and lid) doesn't cost much more than the master kit for the Groco. ...which, btw, may not solve the problem...'cuz it sounds like it's recirculating, which indicates wear to hardware that rebuilding won't cure. I see that a lot on older Groco Ks.
