Perkins 4-108 engine parts available...
I replaced my 4-108 seven years ago and have been storing a few parts in my sister's basement. I want to get rid of them - open to any reasonable offer for the lot - will not seperate:
One set of rebuilt injectors. Rebuilt over ten years ago by reputable diesel service company in Chicago but never used.
Engine rebuild gasket set plus some other gaskets - I think there is at least one complete set
Fresh water pump rebuild parts - shaft - impeller - bearings.
Set of high pressure injector pipes - unused but not sealed so they would need to be cleaned before use.
Damper plate to match 4-108 to a Hurth - ZF transmission - used one year - a lot of life left in it.
An adapter to use spin on fuel filters in place of on engine canister. I had sold this to someone that said the canister mount had to be machined to use the adapter so I took it back. A few spin on filters to match.
One original and one photocopy workshop manual.
A few misc. copper and aluminum washers for banjo fittings.
If interested email me at: systormalong - at - yahoo - dot - com
