Return to Index
Read Responses
Good thought. You can buy liquid nitrogen at any drugstore
In Response To:
Other side of heat is cold. Put an ice cube or even shoot Freon at the plug?
It's sold under various trade names to freeze warts. That would be worth a try.
Frozen Waste Fitting
Jan, I had one stuck once and
Along the same lines... what is a good material to prevent such fittings from seizing?
Remove it more often!
Good Advice Peggie!
lanocoat
Thx All!
Hey Jan -- read your article in Sail
Thx Larry!
