New Frigoboat system at J Gordon, Back Creek
Annapolis. The new compressor for the Glacier Bay had the wrong fittings and also a bigger receiver/dryer, so wouldn't fit in the Glacier Bay case. Bit the bullet and had J Gordon install a new Frigoboat water cooled system. So far so good, got the one with the mini freezer box so we have ice for drinks and could even keep a little ice cream! J Gordon was good, let me remove the old system and work with their tech a little to make sure everything fit the way I wanted. The tech was good and knows his stuff. Dockage is free while they work on your boat, you can do other work on your boat while there, they do just about everything except rigging. I would return for other work if I didn't want to do it myself. We are now in Solomons, missing a good sailing day while we provision and do some other shopping. Then probably a few more stops checking out interesting Chesapeake Bay spots before the ICW or Atlantic depending on weather. We should be in the Bahamas by early December.
