thanks Rich
I'll check the manual -- it's on the boat about an hour away. I know that I can easily get to the heat exchanger easily which is why I would like to drain there but will look for plug/drain locaton. I would like to drain the system to get rid of years of unknown antifreeze and will add one season (red - not the pink water tank stuff) antifreeze as appropriate
