Has anyone used the C-Map PC Planner? I got a small CP-180 with C-Map last summer (it worked great!) but found it a bit of a PITA to route plan or modify waypoints sitting in the cockpit. The PC planner supposedly lets you do all that on a bigger sceen elsewhere and load in on the plotter at your convenience. Anyone try it? Best regards, David
