The direction is away from my arm, in shear with the bolts, and at a slight angle (perhaps 15-20 degrees) out from the mounting surface as shown. The fitting is oriented correctly. If direction of pull was toward my arm it would cause the fitting to distort, because the bale wouldn't be able to fold over fully in that direction.
