I have an old Guest 6 AMP charger - no problems
It's one of the older "potted" designs. Had it at least 10-15 years and it just works. It's present use is to trickle charge the deep cycle battery I use to power my basement sump pump. (I have an AC-powered pump also, but a 4000GPH 12v bilge pump is my storm backup in case power goes out and I'm not home to hook up and start the contractor's generator.)
