I need a good sealing tape for foam (pipe) insulation around copper refrigeration lines ...
... that is in the engine pan area, it doesn't get wet, but it's under my engine coming from the engine drive compressor. I've tried a couple different tapes, they all peel loose within a year. My insulation is not the self-sealing kind. Something super sticky. Any suggestions ?
cheers, John
