Return to Index
Read Responses
That's right. If you go overboard and the water's cold your chances diminish rapidly
In Response To:
I don't...as I read it MOB ain't boat sunk but we got the gear..it's one person in the water...
This link says it all.
Hypothermia
EPIRB question ... my ACR #406 battery is expired, why ...
GEPIRB/PLBs
Do they not make PLBs that automatically trigger when submerged?
The PLB is not registered to the boat, so CG is not notified
According to the USCG, Rescue21 is only effective in the areas shown.
That's correct Larry, forgot to mention that ...
Yup. And if the water is cold you'd better hope someone can respond to your VHF
What and "they" will be there in minutes if signaled by EPRIB?
Yessir! When we sail in Spring the water is very cold around here and I consider becoming MOB a death sentence.
I think that's stretching it a bit ...
that's why most matelots in the Andrew never learned to swim.
I recently thought about the same issue....
Now that we have this figured out, which PLB do you buy ...
