Seems to me, that any normal cycling of the weather systems will lead you to fast a wind that will have northern component.
It's not a case where you can head west easily. I yield to those that have done this before. The trip from the eastern Carribean has a much less involved intersection with the Stream because you can, if you wish, push thru it or ride it a bit.
