Repair or 'rebuild'? Metal or 'plastic'?
There are some newer laminate panels that have a polyethylene fascia already bonded to the FRG backing ... all you have to do is 'weld' the joints. Either build from new or to 'line' (build a new tank inside the old tank) with; Polyethylene the probable BEST material versus chemical 'leachables'.
