I have the Grabits and like them. Of course, EVERYthing works well in brass...
The SS is the hard part. Often I have used Cobalt small bit to center the screw...as best I can...and then move up from there. IF worse comes to worse, I take a suitably sized bung cutter, say a number 10 or number 12 or what is close, go around the screw, extract it more easily with finepoint vice grips and then rebung into the hole.
