There is also the opposite
The PO of the Islander upsized most of the running rigging. It does not move freely through the rope clutches he had installed, also does not work well with the ST lewmars.
Even though it has seen little use it will all be replaced in the next 6 weeks......unless it doesn't stop snowing, then it might be 8 weeks.
