Volvo tachometer
My tach is starting to act a little weird when I first start the engine,the tack jumps up to about 4000RPM when first started then settles down to normal RPM.
My question is there a way to determine if the problem is the tack or the alt, any and all help is appreciated. The engine is a Volvo 2003 1990 model.
Mike
