Don't even think about removing it with the PoliPrep. That just pushes it around. You need the remover in the spray can. It took about 1/2 hour to remove 40 linear feet of PoliGlow versus hours the other way.
The picture is gelcoat after removing the PoliGlow, compound grade, polish grade, then wax.
