Tentmaker
In Response To: Tentmaker sewing machine ()
Kathy,
I recommend you direct your questions to the supplier of the machine. If it's faulty, they should correct the fault under warranty. If you need directions on maintenance, they should supply them so you can keep your warranty valid. Oh, used machine - no warranty?
Hope you didn't pay much for it. There was a used one on eBay recently - $280, no bids.
