Return to Index
Read Responses
Some folks use PEX pipe and fittings
In Response To:
Water tanks: translucent poly vs. black ABS RV style.....
Same as in a house. Whale makes a system of fittings that seem quite easy to use as well.
re: water tanks
Doesnt matter .....
I s'pose. Ah well, nuthin' is ever easy.
The advantage of translucent is you can see the sluge through it if you're not good to the tank.
Ronco Plastics is your best source
I just received my Ronco replacement holding tank today
That holding tank guarntees that you'll have hot [effluent] if you motor much ;^)
Yeah -- hot sh-t?
In some ways, with the engine running
Not an issue
Plastic tanks and hoses don't like temps above 110F at all
Why is that Peggie? 110F is way below the melting point.
I only know what the mfrs tell me...
Gas permiability? Accelerated degradation of that feature of waste hose.
'Creep' is the problem
Enhanced fermentation?
Good thoughts and info, folks. Thanks for the input!
