I use rectangular zincs just through bolted to the hull. I use two SS bolts with a light smear of bedding compound under the zinc. I am careful about the threads of the one bolt I use for the electric contact. If you have a "drivesaver" in the shaft be sure and put a jumper across it to provide an electric connection for the shaft/prop. I do not worry about being able to replace the zinc while in the water.
