Blowers extract air from your engine compartment which creates a bit of a pressure drop. Fresh air normally then comes in from an air inlet but some will be drawing through openings within the boat. If you have any kind of an exhaust leak the pressure drop from the fan will help to keep the exhaust from finding it's way into the boat. Without the pressure drop it is more likely that CO could leak out into the boat.
