Makes a lot of sense
In Response To: Doesn't make sense to me. ()
Instead of using drag to generate electricity (e.g. wind gen or prop in the water) it would use the cyclical motions of the boat as it gently rocks in a slip, at anchor or under sail. Think of the centrifugal energy that's wasted within a mast as a swings through its pendulum arc -- imagine if that was put to use to generate electrons.
