I found some nice small syringes for an inexpensive price ...
... from AllegroMedical.com, although probably any medical supply source would have the same things for about the same price. These 10ml syringes are called Monoject Oral medication syringes. The graduations on the side make for easy mixing, however, the markings will wear off when rubbed. They come with small plastic caps that go over the tips, so the epoxy doesn't go all over the place. You can also get them with a 3" flexible tube that fits over the tip to get into tight places. I use them for a number of things ... epoxy, glue & adhesive, grease, engine oil into spark plug cylinders, and so on. I paid $16 plus shipping for a box of 100. Way cheaper than Defender, McMaster-Carr or any fiberglass supplier.
Cheers, John
