ST60 transducer wires .. Does the shrink close all the way down on the insulation of that small 22g wire ?
Your wire looks a bit bigger than my ST60 wire. I have 5 (red, green, yellow, blue & shield) and looks like you have 6, with a larger black for ground while mine is the shield. My ST cable is black while yours is grey.
Thanks ! Cheers, John
