Definitely a drip loop and...
Grommets do not keep out water, they only protect the cable from abrasion. The cable should exit from a position where it will not have tight bends. No need to exit above the dome. Anyway, you do not want RADAR beam (high power short burst) interfering with it's own interface to the display. Probably doesn't matter if you have the new, low power broadband RADAR.
