I use a basic Brother P-Touch with the TZ labels. The TZ labels don't turn black from heat nearly as bad as the basic ones do. I print the label then cut clear heat shrink, you can buy four footers at HR Distributors in Portland, and heat shrink clear over the Brother label...
Here's a shot of some labeled wires..
Also works well for duplex wire:
