We have one
In Response To: Wilson Cell Phone Booster ()
It works pretty well. I can often go from no data or 1X coverage to a solid 3G signal and from no way to make a call to a good clear call. The higher you mount the antenna the better the performance. The antenna has to be far enough from the internal antenna to not cause feedback..
It was expensive but is proving its worth...
