Please...
In Response To: Hanging Zincs ()
Please get a corrosion survey before you add more zinc. You can over zinc and under zinc and you really need a reference cell to know what is right for your boat. To much zinc can be as bad as not enough and the right balance all depends on your underwater metals to zinc ratio and the meter reading......
