Has anyone found a neat drop-in dock for charging an iPhone 4S?
So far, we use a usb socket/charged plugged into a 12 volt cigarette lighter type socket, but that leaves the phone at the end of a cable, and is clumsy to connect..
I want a charger that I can fix on a shelf, can be used one-handed, and will hold the phone in a seaway
The only ones I have seen would need a bit of woodwork to anchor down, and are none too secure.
Ideally, one that will accept an iPone 5 too, perhaps with the Apple adapter
