You folks know of any good sources for "waterlock mufflers"
Yup, the next item in my exhaust system is also nearly clogged too... at least the opening right where the exhaust hose from the engine enters it is rather clogged.
I can put my finger in the opening, but just barely... so there is about 1/2 of an inch diameter or so of an opening... seems a bit narrow to me.
I found the vetus site, but their catalog seems to be in German.
I suppose I could try to chisel this clean, but this is a plastic box and I suspect that the plastic is not nearly as strong as the "rocks" that have formed in the inlet opening.
Thanks in advance.
