But your system over all has much more corrosion on it than I had. Hard to believe there was little internal blockage.
My Waterlift Muffler is also partially blocked... I wonder what lead to what... older exhaust system with new engine or new engine blocking older exhaust system.
Paul, what engine do you run?
As an aside, I am living on the boat this weekend, so putting off mechanical projects for the moment.
