The hoses and elbow fittings between the tank and the filter. After fairly expensive hand cleaning and polishing I still had fuel starvation issues at 1/2 tank or less when the vacuum was such that gunk in the form of a "flapper" sealed an elbow fitting shutting off fuel. The same symptoms as clogged filters. If your going to the trouble of cleaning the tank, replace the lines, as well.
