The only sure fire test is to pull the cord..
In Response To: Test & maintain. ()
Failure of the vest is most likely to happen when it is inflated from the CO2 cylinder due to the sudden inflation and the cold temp of the inflating gas. To check if the vest is OK, just yank the cord an let it inflate. If it stays inflated, then you are good to go and can replace the cylinder.
