You are probably fine to mask after 24 hours...
The paint will continue to harden for a couple of weeks, but it will be hard enough to take tape after 24 hours as long as the temps were above 65-70 most of that time. I would use a smooth tape like Scotch 2080 or fine line rather than a typical textured masking tape.
