McLube One Drop is definately best, IMHO
In Response To: What is the best lubricant for ()
I've been using it for the last three years and its really better than the McLube dry lube. The dry lube can be too slippery and cause the balls to slide instead of roll, causing a flat spot. This stuff is engineered for this purpose.
http://www.mclubemarine.com/onedrop/
