I use only FTZ
I use only FTZ Crimp-N-Seal terminals. Harder to find but excellent quality for heat shrink crimps. Sailboatowners.com (your gracious hosts here) has them for a very good price.
I would also recommend polyolefin not the nylon ones. Ancor does not make a single crimp terminal they "source" them from the cheapest vendors. This is why nearly every time I have to buy Ancor, in a pinch, the terminals are different than the last ones. They have zero consistency with their terminals and they can range from ok to pure junk. For non heat shrink I will only use AMP PIDG terminals.
SBO FTZ Rings
