DP's 'radial' Hydra Net is a laminant.
In Response To: Radial cloth - what's this? ()
Dimension-Polyant (a/k/a DP) was mentioned by Craig. Below is a link to the DP site. Craig said he was considering Hydra Net.
http://www.dimension-polyant.com/en/Hydranet_2_2.php
For those that aren't familar with the cut differences - here's a diagram of the difference between the conventional panel cuts and the radial panel cuts of a mainsail:
http://www.fxsails.com/sailchoicearticle.php
