As for Valvetec, those additives the Valvetec provides may or may not be adequate. I would just add your own, regardless.
The big difference that some Valvetech fuel provides is if it has NO is if you use gasoline is alcohol in the gasoline. Alcohol is very rough on a bunch of things if it sits very long inside your fuel system or engine.
